westend
Sep 03, 2015Explorer
Usually. you can lift the EPDM membrane off the rotten roof sheathing if the damage is towards the edge of the membrane. Some rotten wood may stick to the underside but is easy to remove. After completing the wood repair, glue the membrane back down with EPDM adhesive.
Tears or cuts can be repaired with Eternabond tape.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
