isonychia's avatar
isonychia
found soft spot in floor
Hi,
We purchased a used travel trailer about 2 years ago.
Unfortunately, this year we found a soft spot in the floor.
It's about 12" x 12".
I have inspected the roof, slide outs etc many times and never saw any signs of failing seams etc. I obviously missed something.
The one thing we did notice upon opening the trailer for the season is it leaked inside from the AC unit.
The TT sits in a campground and never moves. We use it from April-July.
I was hoping for some guidance here.
I know I have to figure out the leak and do the repair. The repair is going to be difficult. I am skilled at carpentry and construction, so it's not the process that will be hard (I'm sure it will not be easy). It's the fact that the location is not close so I need to bring all my tools and TRY and anticipate what materials I will need. There is a local lumber yard so thats a bonus.
I guess I will start with the leak.
The AC unit is more towards the front middle of the trailer. The soft area is near the refrigerator and bathroom, near the back of the trailer.
Once I fix the AC seal/leak, I don't know how to track down the source of the leak that caused the soft spot. At this point I am assuming it's a roof leak or something in the bathroom. I know the water heater would leak into the bathroom through the drain plug FLANGE. So when I would reseal the anode rod or release the pressure after winterizing, the water runoff would enter the trailer through the flange. The water heater itself does not leak. (I don't think)
My idea is the following.
Can I remove the boards that seal up the undercarriage of the trailer and access the damage from there? I figure this will allow me to see the extent of the damage without tearing up the linoleum, carpet and removing the dinet couch etc. I also figured it would help me follow the path of the damage and maybe find the source/origin of the water entry.
I can only assume how the TT is built. I assume when I remove the undercarriage skin, I will see 2x4 type framing (not sure framing dimensions on a TT), insulation, pipes, wires and the subfloor. Does that sound right?
I have a bunch of other questions but I don't want to add too many at once.
Thanks,
iso
