Frankandbeans
Sep 04, 2015Explorer
Thanks for the reply. So it is on the edge of the membrane (Where the rain channel on the side is). How far off would my plan be in this case?
- Remove that rain channel to remove the screws/staples on the side holding the EDPM down.
- Cut two slits in the rubber roof so that I can peel up, starting from the edge obviously, the roof allowing me to access the rotted wood.
- Repair wood and use whatever EDPM glue to adhere roof to the new repaired wood.
Now the big question - what about the seams from the cuts? Obviously it should be mostly sealed from the glue that I would imagine would overflow out of the cuts, but just to verify, I can just use the Eternabond tape to seal that seam, right?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
