- Colo_NativeExplorer
phillyg wrote:
TNGW1500SE wrote:
The bolts look dry to me.
I think the above was meant to be humorous as the wet bolts are not in the photo. WRT to the second photo, and while it's difficult to tell, it appears the new u-bolts are too long and might hit the gas line at full spring compression. I suggest grinding off the tips.
The tire will hit the underside of the slide before the gas line - Colo_NativeExplorer
Lynnmor wrote:
Colo Native wrote:
the tire in the picture was rubbing on the slideout rail and there was about 1/2" of clearance so asked in a previous thread and the general consensus was bad springs so I changed them and got about
1 1/4" clearance from that slideout rail now
The springs certainly needed replacement. If that 1 1/4" is the vertical clearance above the tire, it still may not be enough.
It is poor design! the bracket is toward the front of the rear tire I have another trip planned and will evaluate then. The new spring has 1 more spring there are 5 instead of 4 and the higher capacity. - phillygExplorer II
I think the above was meant to be humorous as the wet bolts are not in the photo. WRT to the second photo, and while it's difficult to tell, it appears the new u-bolts are too long and might hit the gas line at full spring compression. I suggest grinding off the tips. - LynnmorExplorer II
The springs certainly needed replacement. If that 1 1/4" is the vertical clearance above the tire, it still may not be enough. - Colo_NativeExplorer
time2roll wrote:
I bet it rides better too. Was there an issue that prompted the replacement?
1 1/4" clearance from that slideout rail now - I bet it rides better too. Was there an issue that prompted the replacement?
- richardcoxidExplorer IIThe term "wet bolts" refer to the thru bolts that go thru the spring eyes/shackles and are drilled with Zerk fittings in the hex end to use a grease gun to lubricate the pivot points. "Dry Bolts" are not lubricated with grease, they usually are inserted "dry" thru those worthless Nylon sleeves.
- TNGW1500SEExplorerThe bolts look dry to me.
- WNYBobExplorerGood job, looks like the old ones were flattened out!
- LwiddisNavigatorLooks good! Wish I could have watched to learn.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
