- jplante4Explorer II
Ron3rd wrote:
Allure makes 2 types; one that has a peel and stick edge and another that is a snap and lock type. I've read here that the snap and lock is the better way to go.
I went with the grip strip. Adhesive on all 4 sides. It seemed like it would be more stable. - Ron3rdExplorer IIIGood thing about Allure and other brands is they're made of vinyl and can get wet. IMO this is a better choice than the wood laminates. The vinyl might be more temperature stable too. Allure makes 2 types; one that has a peel and stick edge and another that is a snap and lock type. I've read here that the snap and lock is the better way to go.
- LwiddisNavigatorMan, moderator, that floor looks good!
- Bill_SatelliteExplorer II
Grey Mountain wrote:
We want to replace the carpet in the front area (two slides) with wood/laminate. Anybody have a ballpark price for materials and labor for such a job?
GM
Ernie in Weatherford, TX is likely the best at this kind of work if you want a professional and he uses hardwood and not the cheap laminates. I would guess he would be in the $3000 range for a 40 foot coach but you should contact him for information and a reservation as he is usually booked out 9-12 months. - Grey_MountainExplorerThanks, Mod. Checked out that link. You can close this one.
Thanks, all.
GM - jplante4Explorer III did the front half of the Sahara with Allure from HoD. $300 of material and I had a half box let over. I also bought a roll of rosin paper. It took 3 days, 1 of those ripping up the old floor in the galley area.
The jury's still out on whether this is a good solution for a motor home. They don't recommend using Allure in a non-temperature controlled environment. The trick is to make sure it floats. Do not screw or nail anything through the vinyl into the subfloor. This floor has been through all 4 season in New England and it still looks great. - ScottGNomadWithout knowing the area size, exact material or even the area your located in, it's impossible to say.
- LwiddisNavigatorWork by a pro or by you? Square feet? Quality desired? Is carpet easily removable? Subflooring type and condition?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
