dennych1's avatar
dennych1
Replace dinette foam
Looking to order foam from the foam factory not sure to go with hd36 which says medium firmness or lux which is firm to extra firm. Has anybody gone through this
Thanks
Dennis
  • I forgot the vendor I used when I replaced my dinette cushion foam a few years ago. I had the same concern and ordered the extra firm foam. It was Ok and if anything less firm than I wanted.
  • I saw this thread a while back and decided I really needed new foam for my dinette. I ordered from the Foam Factory as others here did, just clicked on seats and cushions and followed the instructions.
    I got the Lux Foam - High Quality WITH DACRON WRAP,WOW what a difference,firm butt very comfortable!
    I followed the measuring guide and the fit was perfect.
    One of my best up-grades I have made.
  • I did it twice so you don't have to. I put a layer of 36 on top and a layer of lux on the bottom. It wasn't firm enough so I did it over with all lux. It always gets a little softer from use so if it feels too firm at first, it will soften up some. I think I used their high quality stuff to get a longer life out of it. Cheapest way to buy it is to order it in a mattress size and then cut it to the dimensions you need. An electric carving knife is amazingly great for this task. Walmart has one that's less than $20.
  • dennych1 wrote:
    Is the lux very hard
    It's firm but with enough give that it's comfortable.
  • I got my foam from a local furniture factory. I used the firmest they had and believe that you can’t get foam that is too firm.
  • We also went with Lux-High Quality. As ependydad said MEASURE !!. Great upgrade for my big butt on our dinette.
  • For my dinette cushions, we went with:
    > Mattress or Cushion, Lux Foam - High Quality WITH DACRON WRAP
    Just make sure you measure as they instruct you to. I didn't and split a seam trying to get one zipped closed.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
