JaxDad
Jun 29, 2018Explorer III
I’ve successfully replaced the pivot pin in a piano hinge with a slightly smaller piece of stainless steel rod with a finger pull on one end. With the finger pull looped back on the rod it’s inside the door when closed and maintains security.
Open door, pull rod out, voila! Door is off.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
