GuyCanRV's avatar
GuyCanRV
Explorer III
Dec 30, 2023
Solved
Replace insulation inside heater column.
I just had my Dometic fridge cooling unit repaired and am putting everything back together. I was watching a good video on this subject and the experienced guys (with their own company) recommended...
  • opnspaces's avatar
    Dec 31, 2023
    Thanks for the link. The insulation is available at any home improvement center. From the video it looks like it's standard unfaced R-13 insulation at about $22 a roll. Unfortunately at least at my HD they only sell R-13 faced (with paper backing) and unfaced is special order. If that's all you can get though, it's easy enough to peel the backing off the insulation before use. If you own a house you can just roll the remainder of the insulation out in the attic.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
