Me_Again's avatar
Me_Again
Explorer III
Sep 25, 2018
Replaced Coleman Mach Themostat with LUXPRO
Here is the wiring diagram I used to wire the LUXPRO stat I bought on Amazon for 29 bucks and change. This is a 5-2 day programmable unit.
I did not install a switch for low high fan, so the green wire was connected to G and the grey and blue Mach wires were taped back. When testing there is a 5 minute delay built in before you can test the other function, like cooling after testing heating. I just cut the Mach colored wires about 3-4" from where they are soldered onto the Mach circuit card and stripped the insulation to make the connections to the LUXPRO. Jumper in LUXPRO should be set to gas.
I have used a very similar LUX model before, so it is like old home week.
Chris
No RepliesBe the first to reply
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
