LarryJM
Jul 08, 2014Explorer II
jspringator wrote:
Larry, would RainKap be helpful for my application?
http://www.rvaccessorypart.com/page/page/3352092.htm
It would bypass the Jayco Eagle gutter system that has a gutter and a small tube with a slit in it underneath the gutter. I guess the small tube is to collect water that goes over the gutter. My awning is underneath the molding, but I'm not sure there is enough space to mount the RainKap. I guess I could cut it down.
This would address the issue presented by Gjac. I do'k know of any other way to seal the molding unless I covered the entire thing in Eternabond.
It probably won't fit over the awning, but you don't really need it there. Take a look at the "Eternabond Install" link in my signature and read all the captions for how I used the Eternabond to seal things like that top trim piece along the roof, screws, and about anything else you can think of on a trailer that needs sealing.
Larry
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
