Grizzy's avatar
Grizzy
Replacing cam locks on storage doors
Hi, Has anyone replaced the storage door cam locks with the new (slam door handles? I've searched and not found any posts on the topic. Is it possible or is the door made different now for this to happen reasonably? A little more security would be nice. Thanks
  • I bought slam/push button locks from Teddies in Texas....they work great and were easy to swap out...I bought a matched set so the same key fits all the locks I bought....
  • Thanks MO
    I was thinking that the doors might be thicker. Guess I will have to go the way like the other guys and change out the lock cylinders.
  • On my 5th wheel the doors that have the slam latches are a thicker heavy duty door (almost twice as thick). I don't think they would work on a standard door.
  • locks keep honest people honest...nothing more...but at least they can't use their own key. I used the combo lock
  • Thanks, Mike
    I do have a couple of cylinders I changed out on a former trailer that might work.
    While looking at newer 5th Wheels I've really enjoyed that they have improved the cargo door latches/locks with a more sturdier secure handle. In reality, they are not going to be very secure for a real thief.
  • I replaced the CH751 storage door locks with a "barrel" lock. There is a thread here on RV.net, link below. You might need to paste the link to work. Note that the place I ordered them from is called IHL "Industrial Lock and Hardware". YOu have to take some measurements but in the end, it is a better lock. Hope this helps.
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26834329/gotomsg/26835184.cfm
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
