New_Mexico_Road's avatar
Jul 05, 2013
Replacing carpet with laminate flooring
I am thinking of replacing the carpet in the dining area with Laminate. Any suggestions on getting the carpet out from under the slide, and how would you get the new flooring secured under the slide? Im sure it can be done just not sure where to start.
  • If the carpet is glued down, you should be able to remove it with a large putty knife.
    You may be able to soften the adhesive with a heat gun or a solvent such as mineral spirits.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Nov 28, 2025
