Golden_HVAC
Nov 22, 2015Explorer
I would buy a Fantastic fan and install it in the place of the A/C. The standard opening is 14" square (nominal) and should fit fine.
You might also consider installing the new fan in a new hole in the ceiling, not replacing the A/C unit. Many will not buy a trailer without a working A/C unit, or reduce the amount they will offer substantially. . .
Good luck,
Fred.
Good luck,
Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
