davisnate
Sep 15, 2013Explorer
Replacing Dometic Comfort Control w/Simple Thermostats
I have a 1998 Holiday Rambler Imperial with a heat pump in front and a regular AC/heat unit in back, both ducted. They are connected to a thermostat by a phone wire. I would like to remove the Comfort Control (which does not really work) and install one thermostat for each AC unit. I can get new wires to the units, because there is a opening that runs across the ceiling from one unit to the other. I also have part of the ceiling out, so I can get wires to a wall. Can these be rewired to run without the Control Comfort? If so, how do I do it? Thanks!
