time2roll
Jul 15, 2020Nomad
Ed_Gee wrote:Maybe. There would be nothing wrong with giving WFCO a test run. First trip let the battery get down to 12.2 volts and fire up the generator. Voltage should steadily climb to 14.2+ volts over 20 to 60 minutes. Otherwise time for a converter swap. WFCO is notorious for just charging at 13.6 volts regardless of the description in the operating manual.
According to the product description of his current charger converter, it does have Bulk, Absorb, and Float stages of battery charging. It also has battery type selection for wet, AGM, and Gel type batteries. It appears that he does not need to replace his existing charge converter.
I recommend this test for anyone that has a WFCO and charges the battery using a generator.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
