RVcircus's avatar
RVcircus
Explorer II
Feb 23, 2016
Replacing our RV electric cord hatch
On our last trip we added replacing our electric cord hatch to the list of needed repairs. Dealing with brittle plastic parts has become part of owning an older RV, so on our last trip to Camping World we picked up a replacement.
Foolishly, I assumed that the electric cord hatch would be a 10 minute job just like most of the other pieces of plastic we've replaced. In my mind it was take 3 screws out, replace the cover, zip in 3 screws and seal. Well, like so many other times, I was wrong! The replacement wasn’t too complicated, but the power cord needed to be removed from the converter so instead of 10 minutes it took me about an hour.
Here are the basic steps I took to complete the job:
Step 1: Disconnect from shore power and disconnect the RV house battery. If you're not comfortable working with electric I'd skip this project.
Step 2: Remove the electric cord hatch from the side of the RV
Step 3: Disconnect the power cable from the breaker and pull it out of the RV
Step 4: Install the new hatch using butyl tape between the side of the RV and hatch. Seal with RV specific sealant
Step 5: Install electric cord through new hatch and reconnect to the breaker. Connect shore power, connect battery, turn on the breakers, and test.
Check out our install video to see my handsome self in action:
https://youtu.be/tVqbXcs4Jno
And our related blog post:
http://www.rvcircus.com/replace-electric-cord-hatch/
  • msgtord wrote:
    You did allot of extra work for nothing. I replaced mine and did not have to remove the cord. The replacement cover is "notched" so you can push through the plug without disconnecting from the converter.
    Mine is also notched so all I needed to do was push the cord through. Something else I do... I don't pull my power cord out. I run an extension cord right up to the hatch and keep the plug protected. I have to replace the extension cord every year to 18 months because of sun/salt/elements fatiguing the cord. It is much easier to replace the extension cord rather than replacing the cord to the converter.
  • You did allot of extra work for nothing. I replaced mine and did not have to remove the cord. The replacement cover is "notched" so you can push through the plug without disconnecting from the converter.
  • I thought you were supposed to cut the cord, put in the new hatch and then tape the cord back up? ;)
    Your video is a good DIY tutorial.
    Jim
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,390 PostsLatest Activity: Sep 19, 2025
