westend
Jan 05, 2014Explorer
You'll need a higher pressure pump than the standard RV water pumps. You'll also need to repipe with PEX, using good clamps and fittings. If you have the cheap plastic valves throughout, those will need to be replaced if not rated for the higher pressure.
If this is a question about how to adapt to a shore connection that is 70 psi, the only thing you need is a pressure regulator.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
