Gdetrailer
Jan 05, 2014Explorer III
Whats the reason?
Want more water in your shower?
Adding excessive water pressure is not going to help all that much.
You can only fit so much water through a straw (1/2" Pex Pipe).
My sticks and bricks I have 3/4" water lines through out, run 25 PSI- 38 PSI from a water well. Full blast my shower will pin you against the wall.
You simply are not going to have the same showers in a RV as a sticks and bricks and I for one would not want to test the strength of the plumbing parts in a RV with 70 PSI.
I think you will find a lot of unwanted water leaks in a hurry...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
