profdant139's avatar
profdant139
Explorer II
Jun 03, 2014
Ridiculously simple mods -- let's see 'em!
Most of the modifications posted on this forum are technically challenging -- but this is a thread for the exact opposite. What are your simplest, cheapest mods?
Here are two of mine. First, the door of our trailer has a translucent panel (not really a window) that lets in a lot of light. I rigged up a "blackout curtain" that goes over the translucent window -- it's just a double-thickness hefty bag, reinforced with duct tape on the edges, with zip tie rings in the top two corners. The rings then go over cup hooks above the door frame. It sounds like a joke, but it works very well and is easy to store, and it has lasted for about 500 nights of camping.
This is a shot of the “curtain” when deployed:
And here is a close-up of the cuphooks, screwed right into the paneling:
(Note that there is a little tension on the zip ties, so that the "curtain" does not sag.)
My second offering is my patented freezer-door-holder-opener. On our fridge, there are two strong springs that close the freezer door. That’s great, but there are times when DW needs that door open for a moment, as when she is putting an ice tray full of water into the freezer -- a chore best done with two hands.
So she suggested a wooden chopstick as a prop -- it worked! I added short pieces of clear plastic tubing on each end, to avoid scratching the plastic liner of the fridge (and for better friction than the wooden chopstick provided). Here is the magic chopstick when deployed:
And here it is in my hand, so that you can appreciate the subtle complexity of this device:
OK, now it’s your turn!!
  • I had DW make a curtain the right size on her sewing machine with a one inch seam at the top. I then took a one inch strip of magnetic fridge material and double taped it to the top of the door frame. The matching one inch magnetic strip went into the seam.
    It stays on easily, but separates just as easy without tearing or pulling out anything. When not in use it rolls up on itself, and sits on the back of the dinette seat.
    Here's another...
    Put felt furniture slider stick on bits onto door knobs that bang against walls when they open, or on the places where they hit. I had four or five spots in our camper, and now...silence.
  • I'm hesitant to post this. As you window shade seems to work for what you want it to. However. Shades for those windows are sold at every RV dealer. The fit the window very well, and reflect light out.
    And like you. I found a really simple way to hold our fridge door open. I just stick rubber can cozies in the door.
    One of the best mods I have done. Was to add plexiglass to the screen door. Cut to fit in the tray around the door, and easily removed when we want fresh air.
    I also installed a curved shower curtain rail to give us more room in the shower.
    For real cheap, free in fact. I hooked the TV to the radio / CD, AUX, so that the TV sound would go out thru the stereo speakers.
    Plus, as we never cook in the TT. I made a cover / cutting board top, to fit over the stove burners. Really helps with cabinet top space.
    I am now looking at installing a fan in opening of the bottom bunk to help bring AC air into the cubby hole that is the bunk.
  • Combination bunk edge guard and laundry line. Cut and REI shipping box in two, folded the pieces, put them between mattress and wooden bunk edge. They keep gear from sliding off the bunk on rough roads. Clips hold drying socks or whatever.
  • Missed having a clock on the motorhome dashboard. Bought a cheap ($7) "designer" watch with a big analog face. Removed the watchband, and stuck it to the dash with velcro.
    No photo - it's way too simple for that.
    al
  • Our simple mod. I put this into one of our slides (a slide in a slide)..:)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
