RoyB
Aug 16, 2018Explorer III
This is the Running Lights 'TRICK' the OP is referring too...
Google Image
The JUMPER WIRE can be replaced with an ATC FUSE or the FLASHER if you want the running lights to flash...
I have seen one person replaced the 'jumper wire' with a couple of wires that ran up into the trailer and used a SWITCH to turn the running lights ON or OFF from inside the trailer.
The only positive thing I ever thought this to be good for would be to FLASH to alert authorities coming to your trailer for an emergency...
Roy Ken
Google Image
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
