SoundGuy
Aug 16, 2018Explorer
Bobbo wrote:
I did exactly the same thing, except, instead of a SPDT switch, I used a SPST switch that shorts the pins of the flasher together. Electrically, that takes the flasher out of the circuit.
Different way to skin a cat I guess :W - my SPDT switch is centre off, in which case neither circuit is energized. :B
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
