Aug 19, 2018Explorer II
2112 wrote:As I suspected, this is a low-side switch. You will need a high-side switch due to your campers common ground (tied to frame). It can be done, but not with this device.rjniles wrote:I'm not convinced this will work with a common ground. I believe IN V- and OUT V- need to be isolated.
I use this dimmer for LEDs. Will not work for incadescent, too much current.
https://www.amazon.com/Leegoal-LEDwholesalers-Lights-Dimming-Controller/dp/B003L4KKF2/ref=sr_1_4?ie=UTF8&qid=1534464401&sr=8-4&keywords=12+volt+led+dimmer&dpID=41YcQUHmX1L&preST=_SY300_QL70_&dpSrc=srch
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
