grandpopsicle's avatar
Aug 16, 2018
Running lights on when camping, use a fuse & dimmer?
I really like the trick where you use a fuse on the plug to light up the running lights while camping. However think I would want to tone it down a bit.
Any reason why a dimmer in line with the fuse would not work?
  • gbopp wrote:
    Forget about the dimmer, install a flasher :B
    Ahhh! Seizure. Got enough sensory issues at my age :E. LOL
  • GordonThree wrote:
    If you're still using incandescent bulbs it will work. If you're on LED it may or may not depending on the design of the LED bulbs.
    I do have tricked out leds. Seems as though I just have to give it a try.
  • If you're still using incandescent bulbs it will work. If you're on LED it may or may not depending on the design of the LED bulbs.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
