Vintage465 wrote:
I have a Coleman single burner stove that uses the throw away cylinder to fire it. If it will run off 30psig and the Grill will run off 30pisg, then I will install the reg up at the tanks upstream of the rubber High Pressure Hose.
They will. Back when we owned our Fleetwood Santa Fe which presented a
regulated high pressure feed of ~ 16 p.s.i. via a male 1"-20 threaded fitting on the curb side of the trailer I would split that feed with a Marshall T, use one leg to feed the two burner high pressure outside stove and the other leg to feed my Weber Q100. If all three burners were running full tilt there was a small decrease in performance, but only a
small decrease. In practical terms it worked just fine and I used it this way for 6 yrs.
