high5's avatar
high5
RV AC 521 compressor saver
Has anyone installed a 521 compressor saver on an AC unit? I know hard start 'boosters' are popular but, I haven't seen anything about the 5-2-1 compressor saver. They are usually installed on residential units but they do make a kit for 1 to 3 tons (12,000 - 36,000 btu). It looks like a good low cost alternative to the $300 Micro-air EasyStart unit. They both substantially reduce compressor start current. Thanks for viewing.
  • SoundGuy wrote:
    The 5-2-1 Compressor Saver is clearly a hard start kit as is a Supco SPP6 but the Micro-Air Easy Start Soft Starter Kit is not. Testimonials from those here on rv.net who have installed the Easy Start on their roof top A/C unit indicate this does solve the problem of successfully and repeatedly being able to start & run a 13,500 BTU A/C using a 2K genset such as the Honda EU2000i. If that's your intention the Easy Start is the solution I'd be looking at.
    That is my intention and I've seen the EasyStart testing. It clearly is the superior unit but with a cost/benefit issue. In the tests I saw, using equipment capable of capturing very quick peak inrush current measurements, the 521 3-wire reduced peak current by almost 50%. That reduction plus the addition of a delay relay for the fan, brings the starting current well within the capability of a 2000W inv-gen. The total for a 521 3-wire/fan delay mod is ~$50. The EasyStart reduced inrush by 70%+ but the $320+ cost may not be required to achieve the desired result. If the EasyStart was more affordable, I'd buy it in a heart beat - it's a remarkable piece of engineering.
  • prichardson wrote:
    5-2-1 and SUPCO are both hard start kits and consist of a potential relay and capacitor. Ideally the potential relay operating parameters should match the electrical properties of the compressor. Thus the best and safest hard start accessories to use are those available from the manufacturer of the A/C unit involved.
    According to the tear-down/installation videos of the Supco, there was no relay - only PTC(s). So, it's operation is dependent upon how fast or slow they heat (and cool) with surge current. A 521 does use a potential relay which is directly dependent on motor back emf. I noticed on an installation video in a 13,500 RV ac, that both the PTC and 521 were shown on the units wiring diagram. So, if the manufacturers wiring diagram includes 521, then I think my question has been answered. That diagram also shows there is no relay in a PTC 2-wire circuit.
  • 5-2-1 and SUPCO are both hard start kits and consist of a potential relay and capacitor. Ideally the potential relay operating parameters should match the electrical properties of the compressor. Thus the best and safest hard start accessories to use are those available from the manufacturer of the A/C unit involved.
  • I've been researching this circuit for a couple weeks now and, the following is what I've learned. The 521 3-wire circuit uses the usual boost run cap but has the addition of a relay that reads the back emf of the compressor motor. When the motor reaches speed and the back emf is sufficient to open the relay, the boost cap is disconnected from the motor - stated as the safest method. Other circuits such as 521 2-wire or hard start booster PTC/cap don't work consistently or pose extra risk of failure. The 521 3-wire mod reduces start current to half or better which allows much smaller inverter-generators or more additional loads for the big guys. This mod has been used for decades in HVAC and from what I've read, was included by the AC manufacturers many years ago. There is a question about which type of AC it can be used in safely. Since I haven't seen a 521 mod listed for RV's, it may not be suitable. I believe the Supco hard start kit is a PTC/capaitor. From the tests I've seen, this mod doesn't lower the start current. It works by getting the motor up to speed faster giving a shorter duration current pulse. It also appears to be temperature sensitive and may not not work under certain conditions. If anyone finds any error in this, please let me know - I'm still climbing the learning curve.
  • What does it do that a SUPCO hard start kit at half the price doesn't do?
  • My two AC's have run for 12 years without one.
    Don't really see the need for one.
    Maybe if you had a very small generator you might need one.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 27, 2026
