wmoses
Jul 14, 2014Explorer
Excellent replies thus far! Thanks.
Ron - Why is it imperative to have metal stems? Only thing I can think of is galvanic corrosion action in way of the threads. If that is the case then as long as you get similar thread metals you will reduce (can never eliminate unless you get exactly the same material) the corrosion.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
