Ron3rd
Jul 16, 2014Explorer III
bshpilot wrote:
man those flow thru sensors really stick out !
they almost look more broad or wider as my thread on "cap" style....if they are bigger than the cap sensors i don't think id be able to get them my wheels.
Question for Richard (93Cobra2771)....how long have you had those flow thru's & how many times have you had to add air to the tires since you bought them ?
My experience is that i might remove my cap style once or twice every 12-15 months (to add air or change batteries)....now that i have the system i don't need to use a conventional tire gauge to check the pressures (i just turn the monitor on)...so I'm really touching the valve stems (and the sensors) far less than i ever was before i had the system.
The flow through's came out after I bought my TST 507 kit. The only negative I've read about them is the fill rate is slow. Maybe cobra can shed some light.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
