wmoses
Aug 03, 2014Explorer
Ron3rd wrote:
Your mod just might work if you can eliminate the flex; that's what cracks the rubber stems. Long term however I still recommend the steel valve stems.
I used 7/16" ID rubber fuel line cut so that when installed there is no play up and down the valve stem. Definitely requires a lot more centrifugal force than the 0.41 oz sensor can generate. I don't expect any more contact with the rim.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
