martipr
Aug 18, 2014Explorer
Ron3rd wrote:
Which one? The metal one? If so you have a bad valve stem and need to put a new core in it. If it's one of the rubber stems, it has probably cracked from the constant whipping back and forth caused by the sensor. Happened on 2 of my old rubber stems.
Yep, the metal one. It leaks where the stem goes into the rim.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
