Ron3rd
Aug 19, 2014Explorer III
martipr wrote:Ron3rd wrote:
Which one? The metal one? If so you have a bad valve stem and need to put a new core in it. If it's one of the rubber stems, it has probably cracked from the constant whipping back and forth caused by the sensor. Happened on 2 of my old rubber stems.
Yep, the metal one. It leaks where the stem goes into the rim.
Any valve stem can leak. Sounds like you have a bad seal at the rim, or if it leaked from the get go, they used the wrong seal or didn't tighten it down properly, or the seal just went south.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
