rhagfo
Nov 21, 2018Explorer III
Sam Spade wrote:
Ground obstructions have little to do with satellite reception.
You need "line of site" to the bird and mounting height of your dish usually won't make that better.
Either you have a straight shot up through the trees at the right angle......or you don't.
You are so wrong on this.
Getting the dish 12’ to 13’ higher may be all that is needed to clear trees that kill reception. I have put our Tailgater on the roof or AC to get a clean sight line to the satellites.
When on the roof nothing under if just the four rubber feet. I do tie it off to keep on roof.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
