Sam_Spade
Nov 22, 2018Explorer
rhagfo wrote:Sam Spade wrote:
Ground obstructions have little to do with satellite reception.
You need "line of site" to the bird and mounting height of your dish usually won't make that better.
Either you have a straight shot up through the trees at the right angle......or you don't.
You are so wrong on this.
Getting the dish 12’ to 13’ higher may be all that is needed to clear trees that kill reception.
Nope. Not wrong. Maybe not clear enough though.
Consider that moving it's location on the ground something less than 3 feet should accomplish the same thing. Your clear line of sight that is a foot higher also intersects the ground somewhere VERY nearby.......if your starting point for that extra 12 inch elevation was ground level.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
