Bill_Satellite
Nov 22, 2018Explorer II
Come on guys. You are both right. Moving the antenna up 12 feet off the ground will often allow reception not at all possible from a ground position. However, in many cases, if you have enough coax, moving the antenna at ground level will allow you to find a gap in the trees as well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
