Bill_Satellite
Dec 13, 2018Explorer II
That mount is designed for the specific foot pattern of the X1 and is not compatible with the X2. However, that does not mean you might not be able to jury rig that base to hold your X2. It will likely involve using the existing "tent stake" holes in the base and running some cords in, under and around that ladder mount base. The other initial problem you will encounter is that the Pathway X2 is substantially larger and will likely not fit between the arms of the ladder so it will have to be mounted pretty high (if that's possible). Let us know if you have any luck but that's an expensive experiment. Maybe you can return it if you can't find a way to make it work.
A couple of bungees and the ladder would likely work just as well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
