DrewE
Feb 14, 2017Explorer III
An air conditioner gasket will seal over most any surface, so far as I know, to attempt to answer your question.
I'm not entirely clear on why you'd need to seal the entirety of an aluminum roof. Aluminum is not porous; the only place where it could leak would be joints or holes, and I'd just seal those areas if needed with an appropriate caulking or tape (Dicor lap joint compound, or a urethane caulking compound, or Eternabond tape).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
