westend
Feb 14, 2017Explorer
Elastomeric paint won't seal anything for starters. I painted my aluminum roof but not for sealing. The white elastomeric paint made the appearance better and dropped temperature by 10 degrees inside.
You can install your A/C before or after painting. The gasket is a mechanical seal, put into tension by the four bolts included for that purpose.
This is the roof coating process with the first spray coat.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
