Jeffzee160 wrote:
I too added a hot water cirulation line.  Click and scroll about 2/3 down the page...
http://www.jeff-z.com/rv/amods/amods.html
Nice job!
There is a way to use a recirc. pump run only when the temp. gets below a preset level.  In a building with a recirc. line, the pump may be on a timer to shut down during the night to save energy.  In an RV, the pump could be on a simple on/off switch or a 0-60 min. timer.  If there was an easy way to re & re our underbelly, I'd consider doing the recirc. line on a pump.  And if you could get underneath the TT, it would probably help to insulate the hot water piping.
