DaYooper
Aug 15, 2016Explorer
If I could have reached all of the wiring that would have been an option, but the black and freshwater weren't easily accessed and I would have had to drop a lot more of the under belly, which was challenging with the cross trailer gas piping.
Either way to run the second display I would have needed to run wire from behind the display back to the basement display. With the very limited room behind the display and switches working with only 2 wires in the fashion I did seemed easy enough.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
