jplante4
Feb 20, 2018Explorer II
I moved ours from the usual place
into a lift cabinet behind the pax seat
There was a recliner and a lamp table there originally. I used the wood from the lamp table to make a new overhead cabinet where the old tube TV was.
A side note: Safari used the TV as a backup camera monitor. That's right, when you turned on the backup camera, the inverter kicked on and the front TV turned on. I needed to replace the camera and monitor, so I went to RVCams and they set me up. No re-wiring, just a few connectors and I could used the old coax.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
