Coach_Cleats's avatar
Coach_Cleats
cabin water pump
Cabin water pump is sending water gushing out fresh water inlet at the post and not thru the cabin faucets. Pump is working but sending water out the inlet.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    some folks warn that what I'm about to tell you will break the inlet.> Well. it's broken already so what do you have to lose? (A dry shirt)
    Remove the screen washer (Get a new one at the hardware as it likely can stand to be replaced. or reuse it)
    There is a little usually white "Button" behind it.
    With water pump on push button
    You will get wet
    IF something is jamming the valve it may flow out.
    Or not
  • Connect your water hose to the inlet and turn it on for a minute or so. The check valve is stuck and running water through it, as designed, may close it and knock the debris loose that is holding it open.
  • Your city water hookup has a check valve inside which allows the water to flow IN and not OUT. That valve is failed, failing and/or is stuck. Whatever the cause, it needs to be replaced so as not to fail again in the very near future. Easy to replace and pretty cheap. Less than $20 buck either from Amazon or Camping World. I've also seen them in the RV section at your local Wally World....Dennis
  • Needs to be a water hose plug as 3/4 pipe and water hose is different threads.
  • City Water hose connection....check valve has failed
    Turn pump OFF
    Remove Screened washer in hose connection
    Then push in on the white center stub and see if it springs back
    Sometimes they get stuck
    But if that doesn't work....screw a 3/4" PVC plug in the hose connection
    Or a garden hose shutoff valve
    *Both at any hardware store
    OR you can replace the whole city water assembly
