Cabin water pump is sending water gushing out fresh water inlet at the post and not thru the cabin faucets. Pump is working but sending water out the inlet.
Connect your water hose to the inlet and turn it on for a minute or so. The check valve is stuck and running water through it, as designed, may close it and knock the debris loose that is holding it open.
