- StirCrazyModerator
Lazz101 wrote:
My battery box is on the outside. The step is secured down, I felt around for screws and can’t find any. It seems to be stapled down. But I don’t want to reef on it any harder then I already have if it screws or something and can’t find them.
looks like they may have moved a few things around over the years. Did you look in the basement and under the bathroom sink? Generally, they are very close to the freshwater tank. - MORSNOWNavigator III
Try taking a magnet over the top and find the hidden screws in the carpet. - Lazz101ExplorerMy battery box is on the outside. The step is secured down, I felt around for screws and can’t find any. It seems to be stapled down. But I don’t want to reef on it any harder then I already have if it screws or something and can’t find them.
- OregunNomad
StirCrazy wrote:
Lazz101 wrote:
How do you get the step off above the water pump to access it on an adventure 910?
I think the 910 has the box of the battery compartment under the step, doesn't it?
No not mine. Battery compartment is outside in the wall. - OregunNomad
Put the slide all the way out and lift up the step at the bathroom side. - StirCrazyModerator
I think the 910 has the box of the battery compartment under the step, doesn't it? - Lazz101ExplorerHow do you get the step off above the water pump to access it on an adventure 910?
- OregunNomadI have a 2013 910FBS Adventurer camper and the pump is up front under the step for the bed just like ssthrd stated above. The cover removes for access.
- Turn it on and listen. Use your ears to follow the sound to find it.
- ssthrdExplorerShould be near the tank. My guess is that it's up front in the compartment under the step up to the bunk.
Have you tried turning the tap on and listening for it?
Or maybe you are asking because it is not working........
About Truck Camper Group
303 PostsLatest Activity: Sep 13, 2026
