Coach_CleatsExplorerMar 31, 2021cabin water pumpCabin water pump is sending water gushing out fresh water inlet at the post and not thru the cabin faucets. Pump is working but sending water out the inlet.
Old-BiscuitExplorer IIIMar 31, 2021City Water hose connection....check valve has failedTurn pump OFFRemove Screened washer in hose connectionThen push in on the white center stub and see if it springs backSometimes they get stuckBut if that doesn't work....screw a 3/4" PVC plug in the hose connectionOr a garden hose shutoff valve*Both at any hardware storeOR you can replace the whole city water assembly
Related ContentWater pump?Water PumpWhy no hot water?Water pumpWater Pump Failure Traveling To The Eclipse
