rhagfo
Jan 03, 2018Explorer III
I will say the biggest plus to this is the shower drains way better! Before the fix with a shorter drain run, nearly flat, the shower pan would start to fill with water and you would need to tap the drain with a foot to get the flow started.
Now the water drains easily on its own, even though the drain line is longer, but no longer flat, nicely sloped.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
