profdant139's avatar
profdant139
Explorer III
Dec 29, 2018
Simple mod for crew cabs: plywood deck over folded seats
This is so simple that it hardly qualifies as a mod, but we have found that it makes a big difference: after you fold down the back row of seats, add a thin sheet of plywood over the backs of the seats, cut to fit the space perfectly.
This has several advantages -- first, because the seat backs are uneven, this gives you a level playing field, with lots of room for your stuff.
Second, you can (if you wish) add baskets onto the plywood deck and secure them to the plywood. This keeps the baskets from skating around, and the baskets help keep your stuff organized. One of our baskets has multiple levels -- heavy objects go in the bottom basket, lighter stuff in the top.
The goal is to convert the back seat from a haphazard mess to a useful and organized cargo space. To tell the truth, though, after a couple of weeks of travel, it still becomes a mess, but it is easy to straighten up.
If you ever need the crew cab seats for actual passengers, the sheet of plywood is easy to remove.
I also added a thin layer of foam to the underside of the plywood sheet, to keep it from making noise on bumpy roads.
My "mod" is so simple that it is not worth posting a picture -- "see, folks, here is what a piece of plywood looks like!" But if you have more elaborate versions of the same thing, I'd like to copy your design, so let's see 'em!
  • Pulled out my seat, put in a platform and now have 2 tier storage.
  • You could always put plywood across the kids' laps -- it'll keep 'em in place for sure! ;)
  • When I had my Ranger pickup, I fabricated a shelf that fit into a groove in the cab and was really handy to have stuff at hand back there. I kept things under the shelf like the ice chest and a box of kleenex and coats water jug up on the shelf. I hid a lot of stuff from view and was as I said handy to keep things up where you could reach them.
    When I bought a 1997 F150 beater truck, I made cardboard patterns for a shelf but I ended up giving the DGS the truck before I got it built.
    I'm currently looking for a replacement for the F150 and will probably get a 2X4 Ranger so I can get rid of the 1995 Sidekick towed that is on it's last legs. I will definitely build a shelf for that truck.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Old-Biscuit wrote:
    My rear seat bottoms fold up....then 'deck' folds out for a flat platform
    More then enough room for anything we carry back there which is usually just groceries
    DD’s 2004 Ram 3500 DRW has the “Folding Flat Load Floor Storage” a very nice option.
  • My rear seat bottoms fold up....then 'deck' folds out for a flat platform
  • I've only got a single back seat in my crew-cab and the seat bases fold up against the seat back. Sounds like your idea would work better in an SUV with seat backs that fold forward rather than crew-cab trucks.
  • I did something similar long ago, but mainly with the idea of protecting the back seats from the dogs. I used blue foam sheet on top of the plywood to give them some traction. However we now have a topper on back since we switched from fiver to TT and I plan to relocate the mutts to that. I need to make some alterations to the topper first before putting the plan in action. The wife of course has low enthusiasm for the mutt relocation plan. I'll keep your idea for the seats in mind tho.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
