fyrflie's avatar
fyrflie
Explorer III
Jan 31, 2023
Slide Out Freezer/Refrigerator
Always wanted / needed additional freezer space for longer roadtrips so this is how I solved the problem. After careful measurements, I found that the Alpicool C40 Portable Refrigerator 12 Volt Car Freezer 42 Quart(40 Liter) would be the best fit. Can be used with 120 or 12 volts.
I made a slide out tray with 100 lb.Full Extension slides and installed a 12 volt receptacle in the compartment.
I have used the Freezer/ Refrigerator on two trips now. One 4 day trip as a refrigerator and a 35 day trip as a freezer. It has worked flawlessly. The compartment was previously used for drink storage or misc. ****. I even made the accessory pouch that carries the 120 volt cord.
  • CA Traveler wrote:
    Nice! I was curious about venting on hot days?
    I haven’t been in hot weather yet, but I am thinking about some vents on the upper edge of the compartment closest to the rear tires. It’s a protected area by the wheel well liner but should allow warm air to exit. This same compartment also houses the converter/charger so some air may be good. Or I can vent it towards the holding tank area. Haven’t decided yet.
