acritzer's avatar
acritzer
Explorer II
Mar 24, 2024
Slide out hell!
Messed up on this one!  I’ll make it short and skip the backstory. The slide out it stuck in the out position, I tried disconnecting the motors to manually push it in but can’t seem to manage it. I’m trying to avoid totally tearing into things.
Coachmen Apex, can’t really get a good look or access to the motors. Should I bite the bullet and tear off the exterior flashing?
  • You can use the manual override on shwintech or undo one screw on each motor, pop them up and push in the slide.
  • Many (most) slides allow you to crank them in by turning the square bar under the slide.
    • acritzer's avatar
      acritzer
      Explorer II
      Thanks. Not this design. Schwintech I believe.
      • StirCrazy's avatar
        StirCrazy
        Moderator
        found this  let me know if that helps, I have no experiance with thoes types of slides.
        Steve
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
