DrewE
Aug 20, 2020Explorer III
CA Traveler wrote:zigzagrv wrote:That would surprise me as the pic suggests a DPDT switch that reverses the polarity to the motor.
I would say the black and green are from the battery and are the source of power for the motor. The red and white go to the motor. You should see 12 volts on the black and green.
How do you suggest the slide goes in and out?
It works exactly the same as if the black and green wires go to the motor and the red and white to the battery. The polarity gets reversed between the two pairs of wires, and it doesn't matter which is the "input" and which is the "output."
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
