RickLap's avatar
RickLap
slide outs
Has anyone installed laminate in an rv with slides? How did you anchor the boards near the slide to prevent it from moving? Or was it even necessary?
  • I managed to figure it out. there are 2 "L" shaped pieces on each end of the slide. you have to leave enough room for those to clear as the slide lifts and slides in or you'll tear up the floor. They are at the very edge of the slide so cut the board back about an additional inch or two to prevent them from hooking it.
  • Mine came with laminate floor angled across in the kitchen area. It's a floating floor and just has a trim piece on the angle across next to the carpeted side.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
