steve-n-vicki's avatar
Jul 30, 2015
slideout topper
I just installed a slideout topper , took 1 hour and 20 min. was not hard to do at all
  • I used molly rivets to attach the awning rail and brackets to the slide , they will expand out in a triangular wing pattern on the back side providing the necessary support , dometic calls them Oscar rivets
  • How did you determine if there was anything there to "bite" into under the drip rail on the aide of the trailer where you attached?
    Any way to really know if the screws you are using are too long or might protrude on the inside?
  • yep dometics are easy did you see the new style with the easy brackets?
    looks good by the way
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
